Brief Description: New BNC connector installed in right fuel tank
I received the parts I had ordered from Van's recently including the BNC connector for the right fuel quantity indication system. I soldered the new BNC connector to the harness, secured it to the tank bulkhead and sealed it. Then I also reinstalled the fuel tank access panel and sealed it. Lastly I prepared the tank for a leak check by installing the air charge valve and capping the fuel feed line. Tomorrow once the sealant has had a chance to cure I'll do the tank leak check.
New BNC connector soldered on and sealed on the right fuel tank
Right fuel tank access panel reinstalled, sealed and tank prepared for pressure checking
